This poll is missing the option - we have already migrated to the cloud
Also missing dual, some cloud / some premises.
Will we all be digitized or will some be allowed to remain analog at least part time?
A mixture of On-Prem and Azure, mainly On-Prem due to cost.
Digital transformation is critical to business continuity. Our organization is "in the denial" phase from an C-Level understanding of what the digital transformation really means for them in terms of security and operational gains.However, with these impediments, our IT org is engaged in a migratory study and TCO analysis for a hybrid solution for remedying this situation. Having in mind the 'unknowns' at the C-Level, we are developing a compelling study to reveal the gaps in our production and interoperability planning to date to create and present information for a better understanding of digital transformation for our organization.
Hi Ben - trying to reach out to you regarding the May prizes. I haven't heard back from you on the next steps.
Modernization is a trend, that's for sure
Alright!
