If your Orion® Platform environment monitors business-critical systems, guess what? The Orion Platform itself is business-critical. But how well do you know your installation? In this session, we'll show how to quickly perform an Orion Platform environment review to help you understand your Orion Platform and SQL Environments, and gain insights on installation, configuration, and optimization. Learn how your system is performing today and what's needed to maintain a stable healthy system optimized to scale and perform to the highest standards.
Resources:
Customer Portal Orion Insights Landing Page:
You are more than welcome Abdul, we continuously release enhancements to Orion Insights month over month.Do leverage it here: https://customerportal.solarwinds.com/support/orion-insightsSimply upload Diagnostics, and a few hours later, the same URL above will automatically return a full Orion Environmental Review will be returned for your viewing pleasure.All the best, Kevin
Amazing and Informative video Kevin !!
@kevin2me
