The way the policy reports come out (at least mine), if you have a very long list of hosts, the title of the violation or check will get lost way up top. I'm not sure of what a good way to fix this would be.
Do you mean e.g. paging?
Regards,
Jiri
I mean the top row of the report, where the checks are listed, stays at the top. If you have say, many pages in your report because you have a lot of devices, as you read down the report, it's hard to follow because the label for the column is 3 pages ago. I hope that makes sense. I am not explaining very well.
If the report could print in out in Excel and you could freeze the top row, that work would. or you could just repeat the top header on each successive page.
Got it. Thanks.
