Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Engineer's Toolset
Moving to new monitor machines
ayehia
HI All
how can i move or backup and restore Solarwinds on a new machine with the same data collected over one year now through old machine . i don't want to loose the databases of network performance and logs of the events .
THanks and regards
Ahmed
Find more posts tagged with
Accepted answers
All comments
rknight
Look for the SWNetPerfMon.cfg in your current solarwinds directory. This is all the Network Performance Monitor information. Copy it to the new machine.
Cheers
Ric Knight
Bryan
You should be able to copy over the SWNetPerfMon.cfg file to the new machine and you could be able to start right where you left off.
Lockheed Martin
Atlas V Launch Operations
Network Engineer
svt
Hi Guys,
First posting
New to Solarwinds.
Moved Network Performance Monitoring Tool to a new Machine.
copied over the SWNetPerfMon.cfg file to the new machine.
Started up Solarwinds and ran Network Performance Monitoring Tool.
After baseline was recalibrated, I found that many of my network devices cannot be polled & discovered. Interfaces now have question mark adjecent to them.
Network Ok
copied sw2netperf-release.dll to SW2netperfMon.dll
Problem still persists.
Still running Solarwinds on old machine.
Can anyone help
Cheers
Steve
Network_Guru
Sounds like SNMP permissions on the devices you are polling.
Make sure the devices allow SNMP polling from the new server(IP).
Also check to make sure your community strings are still OK on the new server.
There is a small utility called SNMPing, which can check SNMP access to your devices.
www.sans.org/.../
-=Cheers=-
NG
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
