Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Node down yet pingable
FormerMember
I have an interesting problem I have a device(2950t) that is pingable all monitored interfaces are showing as up but I have the red dot complex any ideas what would be causing this?
ACK and you shall receive.
Find more posts tagged with
Accepted answers
All comments
bashley
stupid thought, but could the community string have been changed?
larry.rice
click on the device and see if there are any events/alerts associated with it.
FormerMember
No alerts or events other than the 'No response' The device is pingable from the server thats what is getting me on this
Just double checked the community string its still the same as one of the other boxes that are identical to it.
You can see all of the interfaces and the stats for each.
chris.conway
Are you polling it through a firewall by any chance?
If so, it may be that your firewall is rejecting the ping packet that Orion sends as it is not 32 bytes. Try changing it to be 32 bytes under File->Orion Network Performance Monitor Settings and the network tab. Just delete some of the ping packet contents until it reads 32 bytes
Analyser Sales Ltd
SolarWinds Premier Partner
www.asl-solarwinds.co.uk
craig999
Or you could use MTUROUTE to find out the largest packet size :
www.elifulkerson.com/.../mturoute.php
FormerMember
asl-support thanks that seemed to do the trick so we made a few changes and now all is well.
mgibson
I have changed the ICMP PAcket size to 0 bytes and the packets are still 124 bytes in length. Does the Service need to be bounced in order for the setting to take??
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
