This is too much power for any one admin.
Any answer with *quantum* and/or *AI* has to be the correct/best - right? Although I am fond of alternate realities...
I mean, time freeze obviously....but not for any reason other than being able to mess with people
Both Quantum Clone Mode with Control-Z (undo the last change) and the ability to read minds....
Clone mode. More "me"s would make one heck of an IT department. Do I get the salary of 5 people too?
The Data Alchemist
This power goes beyond simply "hearing" the data. It's about transforming raw, chaotic data streams into clear, actionable insights, almost like turning lead into gold.
I HAVE THE POWER!!!
Time Machine with the ability to go back or forward to any point in time.
Be in five places at once means you have to do 5 times as much work...... ;-)
