We've taken some of the SAM 6.0 launch creative, sized them to fit various monitor sizes, and they are now available for download below. Enjoy!
Ha, I'm getting the six foot wall cling of that from the office and putting it on my bedroom wall!
(In hindsight, that sounds really pathetic...sigh.)
Lovely pix
I wish there were more of these for each of the products. Then we could scroll a rotating background with the different products.
There is nothing in the attachements file! I am looking for some wallpapers for our SolarWinds server. Thanks.
