Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Memory Utilization > 100%
[Deleted User]
What does it mean when I get % Used of Total System Memory over 100%?
That doesn't make sense?
Find more posts tagged with
Accepted answers
All comments
riglerst
I have an idea to this problem:
Thinking of Windows Memory: If you have physical e.g. 1GB Memory. If this is getting to less, Windows gets some extra Memory from the HDD Space. So, the value for maximum is 1GB = 100% and Windows takes from HDD extra memory e.g. 200MB, you will have 1,2GB of used memory = 120%
Maybe this is the reason.....
mjhamilton
this is also a bug in win2k... I have loads of servers all patched up to SP4 (this is required for correct reporting of mem/cpu)..... however 2 servers in particular even with SP4 report 200%+ mem usage... and they have 3gig each on an identical build.. I can only think that a MS patch was applied in the worng order and the system may require a reinstall of SP4 to correct.....
Martin J. Hamilton... lost in a sea of snmp...
ftsang
yeah, there is a bug with SNMP incorrectly reoprting the amount of memory a server running Win 2000 SP3. Below is the link on Microsoft's website. The fix is to upgrade to SP4.
support.microsoft.com/.../811436
Seashore
I have an installation with a server with 2 GB of RAM and 2 GB swapfile.
The meter shows 250% memory used.
It is Win2000 but with SP4 so it should not be that bug
It cant be that it calculates with the swapfile for that should only add upp to 200%.
Any other idea?
/SeaShore
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
