\m/
This is mandatory for us under RMF. It's not a choice really and you can lose your ATO if you don't do it.
I wish more people understood the benefits of the CAB and how it can significantly improve efficiency in the organization. The integrated features with Calendaring really caught my attention.
We will get that straightened out, but for the time being, go to the Triple-T landing page for the video - http://thwack.com/ttt
The video won't play. Says it's private.
