Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Map Link to Summary View
marvinio
Been using Orion for a couple of months now, and loving every minute. One niggle that might be a quick answer, is there a way I can assign a Summary or Custom View to an Object on a map?
I basically want to create an object within a map, say a building, and for that object to reflect a new view rather than a object/interface details or another map..
Find more posts tagged with
Accepted answers
All comments
pblatz
Sure can.
First create the view.
Preview the page or note the ViewID.
Second add the object to the map.
Right click the object and select Hyperlink. Check the create alternate URL.
type the following as the URL "/NetPerfMon/view.asp?ViewID=##" where ## is the view ID.
Third. save the map.
You should now be launching the associated view when you click the Icon from the map
P. B.
Success requires three bones--wishbone, backbone and funnybone.
Kobi Yamada
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
