These mount on folder names below C:\Cluster Storage and are co-owned by all servers in the cluster.
Right now, the mount points do not even show up as a monitored disk, let alone dealing with the same view on all cluster hosts.
This is a must for all of us who use hypre-v
Having been using this product in a Hyper-V environment for 6 months now, i surely feel your pain and frustration. Once you start getting to Windows 2012 Hyper-V deployed in your environment things start to get better because the filesystem type is CSVFS - and the mount points will start showing up as "mount points" / data stores with a explicit name.
I countered this problem in our environment by creating a label called isClusteredSharedVolume and then scoping filters/searches/queries etc only to include these items of concern for alerting/trends/reports/etc. I did this because i didn't like the fact i was getting space, iops, etc from disks that I had no concern in the world for in my environment. If you look closely Solarwinds is finding the disks for Windows 2008 - It's just not as you expect to see them beneath a C:\Cluster Storage mount point.
It picks up the name defined in your Failover Cluster Manager beneath Cluster Shared Volumes
If you're not seeing these disks, you've likely got some configuration issue. Don't worry I've had many in the system because nothing wants to work as i expect it too. If you're not seeing the disks might i suggest taking 1 cluster and breaking it out into its own discovery job. I've found that separating all my clusters into their own discovery jobs has been helpful for accuracy of data and spreading the load on the VMAN appliance over time. Not spreading the load seemed to end in missing data because of jobs would overlap and not complete, etc. In each discovery job specify the management IP for each node, and also include the Cluster IP.
It stinks managing separate discovery jobs at times when you change the environment around some. Like in my case, i'm currently removing nodes from 2008 clusters and shifting them to 2012.
Hi uidzer0,
This request is for Storage Manager. I believe your statements apply to Virtualization Manager, which is a different product.
Oh ok, well any real support for Hyper-V would be nice...
Can you elaborate on what you mean for "real support for Hyper-V"?
Surely, we are running version 5.6.2 - the latest release.
1. Searching the word HYPER in Storage manager yields not one result. - Searching VMWare yields many.
2. On the Home page, Under getting started with Getting Started with Storage manager, beneath the Virtualization section - I click add and get asked for my VMWare VC Instance or VMWARE ESX host - no mention of hyper-v
3. Beneath the accordion menu on left, expanding virtualization, then clicking on Virtualization Dashboard it's run amuck with ESX/VMware, VMDK's, etc. Not one mention of anything Hyper-V
4. Looking at a Left Hand san.. clicking the servers tab, there is nothing listed because it can't be configured (see above)
5. Looking at a LUN, i see this neat button Configuration Virtualization for target mapping - Just leads me back to my point #2 and can't be configured.
Unless i'm missing something, there isn't one shred of support for Hyper-V within the Storage Manager system. The features look cool if they could be used....
