This just made my life so much more amazingly simple.
I do what I can, wherever I can, whenever I can, however I can.
I like it! You could make a classy Can-Can dance out of that.
Or join Sammy Davis Junior's Candy Man Can song?
This is a feature that I really like for a growing or changing network. It makes organization easier.
This is great KMSigma. Going back to make my groups dynamic now. So much easier. Thanks!
\m/
