Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
to monitor my firewall cpu,session and memory
garconxx
hye,
how to insert my firewall mib inside solarwinds NPM v8. could somebody help me how to enable custome performance monitor.
Find more posts tagged with
Accepted answers
All comments
m_roberts
In the System Manager go to File > Custom MIB Pollers. In the window that opens up you can add your custom MIB as you need to.
You do not say what firewall it is your needing to monitor, but if you click on New then go to the Private > Enterprises section (simply enter 1.3.6.1.4.1 as the OID, which is the starting point) andnavigate through the vendor list and then within to find which MIB elements you require.
From here you can add this data as a Custom Chart/Graph/Dial etc. in the custom views.
Hope this helps
Prosperon Networks - Authorised UK SolarWinds Resellers
http://www.prosperon.co.uk
dperdue
Also, if the MIB you are looking for is not listed, you can still type in the OID. The only difference is we cannot prefill any information about that OID so you will have to provide the name, description, type, etc.
If you have a MIB that is not listed you can email it to support@solarwinds.net and it will get included in the next update to the MIB database.
David Perdue
SolarWinds Development Team
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
