IF YOU TAKE THIS POLL BEFORE FRIDAY JUNE 9TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
Not totally into automation because some level of involvement from deployment to production ops is needed. Tuning automation for a monitoring system is the rules/guidelines of how you'd like the solution to operate. Solving a routine problem or poking you when its important.
More modules, wider visibility, more correlation - oh, hang on, that's HCO
All good for now.
\m/
