The Network Atalas Crash coarse stated that it can be installed on a Remote PC.
Is there a place that the Network Atalas program can be downloaded?
We drop the installer down as aprt of the NPM install, you could do a couple things, copy .exe to a share and send link only to the people you want to have install or you can turn off the download link by editing the map resource on the web, but before you turn it off, copy the link and send the link to the people you want installing Atlas, it would be something like this.
http://<ip_address>/NetworkAtlas/NetworkAtlas.exe
When you log into the web console, on the Network Summary home page under the map resource, there should be a link to download Network Atlas
Is there another way? We host this for several sites and I do not want customers downloading and installing maps
That did it thanks!
