Have 10 minutes? If you work for or as a contractor/consultant to the government (Federal, state/local/county, public education, etc.), please take this survey about implementing automation technologies in your IT infrastructure. All respondents that complete the survey earn 250 thwack points AND are entered to win one of five $25 Amazon gift cards*!
Does volunteer consulting for a non profit county public safety organization count ? (county volunteer fire department Emergency Services District)
was able to submit though :^}
When you choose the number, it should reorder the items for you according to the number you chose. Were you able to submit?
Either current or have worked in the public sector in the past year. Thanks!
Don't know if it was just me but the part where we rate the items with numbers... no matter what number I clicked on next to an item it kept renumbering everything from the top to bottom 1,2,3,4,5 like that ie. I couldn't re-arrange the numbers.
Do respondents have to be currently working in public sector, or would working in public sector within recent months or years qualify?
