The User Device Tracker v2.5 is now available for download in your customer portal.
The most important enhancements in this release include support for wireless “thin” access points and perfomance improvements. Details can be found in and UDT Guided Tour.
I just upgraded my SQL to enterprise and database updating is still stops . Unfortunately I have had issues with UDT 1.0 , UDT 2.0 and now UDT 2.5 and spent way too much time trying to get this to work. I need to just uninstall it and call it a day. I cannot afford to have the database sync go down for 30 minutes or so several times a day. UDT is a great idea and would have made my job 20% easier instead it costs me 20%.
Thanks for your time,
You can close the ticket
Have you logged a support case? If yes, could you please send me the ticket number?
Beware - UDT 2.5RC and now UDT2.5GA release both causes database sync to stop for 30 minutes or so serveral times a day
