Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
SNMP "Scan" causes floppy access every few minutes
solarNoob
Hello,
I have enabled SNMP on some of our XP SP2 machines so that we can use Orion v8 to gather information from them. Every 2-3 minutes the floppy drive makes a noise as if it is trying to read a floppy disk in the drive. I know it is being caused by the SNMP "scan".
How do I make this stop?
--sn
Find more posts tagged with
Accepted answers
All comments
aLTeReGo
You probably have have the floppy drive selected in Orion under Volumes. Uncheck the floppy drive and it should stop.
solarNoob
Floppy drive access is not enabled... I should have indicated that in my first post. Thanks for the reply!
I can verifiy this by opening the Orion network Performance Monitor, right clicking the appropriate node, and then selecting "List Resources". "A:\", under "Volume Utilization", is clearly not checked.
Any other ideas?
--sn
p.s. I appears to only happen on our Dell Optiplex GX520's... weird.
TMPetersen
I called solarwinds on this issue. It is the way windows handles snmp polling. If you are monitoring any type of volume on the machine, like the hard drive, then it will poll the floppy drive. This is a microsoft issue that I really don't see getting fixed. If you can live with the noise, then great, or I would suggest disconnecting the floppy drive if you don't use it.
solarNoob
I think i found a fix!
If you are using Microsoft products you can use Active Directory to change the following setting:
1) Open the domain policy that applies to your users
2) Browse to Local Computer Policy > Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options
3) Find the entry for "Devices: Restrict Floppy Access to locally logged-on user only"
4) Set it to enabled
It will take some time before your clients are pushed the change and they may need a reboot. That seems to have fixed the problem on my network.
--sn
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
