In honor of the total solar eclipse happening in North & South America today, we thought it would be fun to see who can come up with the best total Solar[Winds] eclipse meme!
Here are a few ideas to get you started:
Solarwinds: When De-duplication of data really matters.
Sent to me from D.C. I'm not much of a memer... takes too much time.
He skipped a stone along the sky and look what was left.
You could pick the image, but wording is:
"The sun is in a warning state, please unmanage"
We missed the Solar Eclipse. Couldn't see into the cloud.
that's a good one...
Weird Solarwinds Problem:
Solar Winds the day you dont monitor without it.
Look at all those little Tie Fighters there... Nice!
\m/
