\m/
Yes, we use Logpoint but may be replacing with Solarwinds in future as Logpoint is extremely unfriendly to use.
We use passwords of at least 5 length
Managed SoC for us, including apps that vendor uses
We use several "security solutions". It is a multi-faceted issue, and it takes a lot more than just monitoring.
Yes we do…and I hope that SolarWinds learn to use 3 party tools to monitor the pipeline…
The solution we utilize in our environment is a hybrid solution for access control, defense in depth (layered defenses), external monitoring and internal monitoring, with refined assessments on a daily basis.
Hmm, a vague poll. In line of the questions in this week of the mission I suppose you mean a solution like Access Rights manager.
Very vague for a poll question - I guess everyone uses some or the other security solution - did the query mean - endpoint security, network security, identity and access, SIEM, application security, ...... the list is endless
The poll question also made it to the Thwack Mission?
