Need support for AIX 6.x agent for Solarwinds. Currently only supporting AIX 7.x For those users with AIX 6.x environments this would be greatly appreciated.
Can you use SNMP to poll the AIX 6.X servers?
Didn't IBM end support for AIX 6.x on 04-30-2017?
IIRC, AIX has a delightful "feature" that adding SNMP support requires re-compiling the entire kernel. It also requires some code from IBM that (again, IIRC) you must pay them for. So if it's not present on the box now, getting SNMP support is a non-trivial task. Agents are far and away easier in this situation.
Anyone should feel free to correct me if, in fact, I am NOT recalling correctly, so that this thread remains accurate for posterity.
SNMP can be added and configured on AIX using SMIT. No compiling should be required. However, NET-SNMP is prefered as IBM's SNMP daemon is highly proprietary and does not conform to certain SNMP standards such as MIB2.
need agent for AIX6.1
