Network World just published a podcast that Jimmy Ray Pursor (geek guru over at Cisco) and I did a few days ago on the Engineer's Toolset, Orion, NetFlow, and IP SLA. Give it a listen.
Flame on...JoshFollow me on Twitter
not the first time an 7 year old posting has broken links...
Unhappiness--the link at Give it a listen. appears to be invalid.
Interesting blog article.
