If I go to edit a 2019 Orion Map and select "Entities", I can not change the icons. I can not change the icon if I select a single object as well.
I have literally hundreds of building maps and am finding I am having to create new maps and delete the old ones to get the 2020 functionallity.
A migration tool or correction to this problem would be a gift from heaven.
