IF YOU TAKE THIS POLL BEFORE FRIDAY FEBRUARY 23RD OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
Had to tell my boss so I could claim the overtime.
\m/
