It would be great to see which Advanced Alerts are associated with a particular node. It would be handy especially when you have a lot of Alerts.
You can place $variables in your alert text or e-mail that identify which node fired the alert.
That's not what I'm looking for. It would be good to select a node and then see which Advanced Alert are applicable to this node.
All my alerts include node details otherwise it would be a pretty pointless alert
Isn't this the "Active Alerts on This Node" resource under Node Details pages? Or am I misreading the request?
You are misreading the request. I'm asking to see which alerts (non triggered) are applicable to a node. That I can check to see if certain alerts will run against the particular node according to my trigger conditions (without having to trigger the alerts).
Could you elaborate and give us a case figure? The way it is described now doesn't make sense to me...
I'd like to look at a node and run that node's details against all the advanced alerts and see which ones are applicable.
So if I don't want to receive any more alerts on a particular node, this will quickly show me which alerts I need to modify so that this particular node no longer triggers those alerts.
Make sense now?
