I'd like better control over my VM Sprawl widgets so I can tailor the recommendations to my environment needs. e.g. Change the consolidation ratio or remove entities from appearing in VM Sprawl.
This was possible in the VMan appliance by changing the queries, but in Orion it is not possible
conguir wrote:This was possible in the VMan appliance by changing the queries, but in Orion it is not possible
conguir wrote:
Great feedback! How would you like to customize them? By date? By entity? What are you trying to get rid of
Hi Serena
what I used to do is, instead of showing the average CPU load for the last week, I chose for the last month, or some other times I changed the number of days to wait before declaring a VM stalled. These are small changes, but very powerfull.
conguir wrote:Hi Serenawhat I used to do is, instead of showing the average CPU load for the last week, I chose for the last month, or some other times I changed the number of days to wait before declaring a VM stalled. These are small changes, but very powerfull.
perfect, thank you that's the information I needed.
