I'm also not getting points since last week
The biggest challenge is being aware of changes that have been made to an infrastructure without letting anyone know. Smaller organisations usually do not have a change management procedure, e.g. when there is only one system administrator.
Is anyone else not getting points?
Vuls that vendors refuse to patch and having to mitigate for their open vulerabilities!
Happy Friday!
