I do not have anything to say as of this moment "!
We've looked at DB monitoring in the past and it was just beyond our budget
I do not currently own any SolarWinds Database monitoring products.
We have had DPA for awhile now. Just added SQL Sentry to the DBA tool belt and they are utilizing the whole picture that comes with SQL Sentry.
no comment
Alright!
