Me as well
Same here.
it's the same here
Same issue here
Visual firewall connection mapping and traffic information in Netpath would be awesome!
hmm having more data added to netpath like traffic information? YES. Also the dynamic generated maps.
traffic information and visual firewall connection mapping
Expanded load balancer environment monitoring and traffic information in netpath
2. Traffic information in Netpath
3. Dynamically generated traffic maps
@danielleh Can you reset the Aug 16 / Day 11 question for me? I answered it but it isn't showing a green check. Thanks!
SD-WAN VPNs in NetPath -Wireless controller/AP maps-Expanded load balancer environment monitoring
yes, I have the same issue.
firewall traffic, SD WANs VPNs in NetPath
Dynamically generated traffic maps / Visual firewall connection mapping
2 - Traffic information in NetPath. 3 - Visual firewall connection mapping.
Traffic information in NetPath / Expanded load balancer environment monitoring
This question's front-end graphic says it's unanswered. But when I go in to it to answer it, it bypasses the answers, says "answered", and shows the answered stats, showing I HAVE answered it. Strange. @danielleh
A facility to support reporting telemetry from custom applications we are building on the network.
2) firewall connection mapping
1st: expanded load balancer environment monitoring
2nd: traffic conversation deduplication
3rd: visual firewall connection mapping
Dynamically generated traffic maps and Visual firewall connection mapping
Same here
Net Path and Firewall traffic.
Commenting again just in case it fixes the "no green mark" for Day 11. Also using exact phrasing for choices 2 & 3, jic.
#2 Dynamically generated traffic maps#3 Expanded load balancer environment monitoring
I thought I responded to this already, but I did not get a green check.
All are actually good ideas, some would be more difficult to implement
@danielleh this question isn't registering as answered for me on the main mission page - can you reset it?
Firewall, SD-WAN, Netpath
Dynamically generated traffic maps/ Visual firewall connection mapping
Dynamically generated traffic maps and Visual Firewalls
Voted on Monday. Not showing
Visual firewall connection mapping and Dynamically generated traffic maps
Traffic information
Wireless controller/ap maps
Traffic information in netpath
Deduplication and firewall mapping
Dynamically generated traffic maps & Wireless controller/AP maps
Deduplication and firewall mapping.
Deduplication & dynamic traffic maps are my numbers 2 & 3.
Visual firewall connection mapping, Traffic information in NetPath
Traffic info, visual firewall connection mapping
firewall traffic, sd-wan vpns
SD-WAN Netpath and SD-WAN Maps
comment
Traffic information in NetPath and Visual firewall connection mapping
Traffic information in NetPath & Dynamically generated traffic maps
traffic in netpath... dynamic traffic maps
Traffic information in NetPath / Dynamically generated traffic maps
Traffic info in NetPath, Dynamically generated traffic maps
Visual firewall connection mapping and Visual NSX maps.
Firewall traffic/mapping and traffic data across the network
(2)Wireless controller/AP maps and (3)Visual firewall connection mapping
Visual NSX maps
traffic info in netpath / visual firewall
Visual firewall connection mapping, Traffic conversation deduplication
Dynamically generated traffic maps, Expanded load balancer environment monitoring
Visual firewall connection mapping/sd-wan vpns
Firewall traffic and dynamic traffic maps
Dynamically generated traffic maps/Traffic information in NetPath
2. Visual firewall connection mappingExpanded load balancer environment monitoring
Traffic information in NetPath & Visual firewall connection mapping
Plus SDWAN controller/edge maps and dynamically generated traffic maps.
How about cleaning up ?sound like everything is perfect ..Is the new trap/syslog app and the new maping app is 1:1 to the old ?
FW Connection Mapping and SD-WAN Maps
Visual firewall connection mapping / Traffic Info in NetPath
Traffic information in Netpath/ firewall connection mapping
Traffic information in NetPath, Dynamically generated traffic maps, Visual firewall connection mapping
Wireless APs, and Firewall
Dynamically generated traffic maps & Visual firewall connection mapping
AP maps and NetPath
2.) Visual firewall connection mapping (3.) Dynamically generated traffic maps
SD-WAN VPNs in NetPath, Dynamically generated traffic maps
Dynamically generated traffic maps/Visual Firewall connection mapping
Traffic information and visual firewall connection would be my other two.
Traffic information in NetPath / visual firewall connection mapping
Expanded load balancer environment monitoring and SD-WAN VPNs in NetPath
Dynamically generated traffic maps / Traffic information in NetPath
Firewall and Netflow
firewall traffic AP maps
2) Traffic info in netpath,
3) Wireless controller/AP maps.
Dynamically generated traffic maps, Traffic information in NetPath
Dynamically generated traffic maps / Visual firewall connection mapping.
Firewall Traffic & SDWAN Traffic
2) Dynamically Generated Traffic Maps ... 3) Visual Firewall Connection Mapping
Traffic information in NetPath would be awesome - it would be great to see speed changes, jitter, loss, etc.
Need a "Not Applicable' category
Two: Dynamically generated traffic maps
Three: Traffic information in NetPath
Wireless controller/AP maps and Dynamically generated traffic maps
