THWACKnation - Are any of you monitoring Windows workloads in AWS? Or even just the OS? Please comment below, we have a team that would like to speak with you!
\m/
Yes, we use the cloud monitoring and for the few servers that are able to we have the Orion agent running on them.
nope sorry.
