nice
seeing the changes, in this case flow pattern changes, new pattern etc...
Being able to see into the cloud would seem to require some monitoring VM inside the cloud I assume?
Bill
From experience, deriving network status by observing how it is behaving (What we see as output)
status of endpoints and traffic levels
Observability provides an end-to-end view of processes that are related to systems and network components.
Observability, to me, means being able to get metrics out of a device, whether logical or physical. This should be errors, overflows, buffering, packet drops, losses, CPU usage, memory usage, temperature, fans, PSU status, etc.
Measuring the internal state of a system based solely on its outputs.
I assume visibility into dependencies and health of the network infrastructure.
Observability and monitoring complement each other, with each one serving a separate objective. Monitoring is a subset of and key action for observability. You can only monitor an object that is observable. Monitoring tracks the overall health of an application. It collects data on how the system is performing in terms of access speeds, connectivity, downtime, and bottlenecks. It then tells you “when” something is wrong. Observability, on the other hand, drills down into the “what” and “why” of application functions, by providing granular and relative understanding into its precise failure modes. While monitoring provides reactions only for known issues or incidents, software instrumented for observability allows developers to ask new questions to debug a problem or gain understanding into the general state of what a dynamic object with changing problems and unknown discrepancies should be typically.
"Observability" seems to be a marketing (made up word) but I'm hoping that it means we're able to tap the telemetry of an infrastructure component. The stream is only as good as our ability to interpret the health of the component and how it contributes to the overall operation of the system or service being offered. I'm confident Solarwinds offers a product that can help us achieve higher degrees of "observability".
I'm assuming it means seeing all the network detail end to end
