EIGRPSupport EIGRP for routing neighbors/changes.
Why was this left out, EIGRP is a routing protocol ??...
I think that it was left out since it is Cisco's proprietary protocol
Cisco owns almost 70% of the global router market share. I think that's a good reason to support it.
Regardless of market share, if enough of the NPM user base request it then it should be supported.
I've done my vote-up; we need more of the user-base to also vote-up this feature request as I'm sure there's more than 37 users (current vote as of this writing) that would like this feature.
Agreed, and my understanding/hunch is that Solarwinds is working on this feature.... although I doubt we will see it next week, but I'm confident we will see it soon....
Not sure if anyone else has noticed, but NPM does see EIGRP route tables, but I don't think it's complete information, and why it's not listed as fully supported, but I just worked in an environment, and we were able to pull EIGRP route information, but it did seem incomplete.
It make no sense the leave the most common Cisco Interior Routing Protocol out...
WOO HOO!!!!! This is on the "What we are working on next" list!!!!
I'd say this is a good feature to metric by however I think the reason it was left out in the past was because if you have 4 Cisco routers and 1 Juniper router then EIGRP is out the window
Well.....if you have 4 Cisco routers and 1 Juniper router then EIGRP may have been blown back in the window, Juniper updates permitting.....
Enhanced Interior Gateway Routing Protocol (EIGRP) Informational RFC Frequently Asked Questions [IP Routing] - Cisco Sy…
If you only have five routers then you're about the same size as my home network, and you might as well use an open standard like OSPF.
cisco are not releasing any of the better features of EIGRP like stub areas, and they'll remain in charge of certifying compatible/compliant implementations, so if there is a bug in their code it'll be up to someone else to work around it. That sucks for ensuring compatibility.
HP Procurve supports EIGRP
Yes this should be added. It would help my atlas maps be more accurate.
It's really about time actually... Orion pretty much started as a Cisco monitoring tool.
Bump!
Number 500 bump but I don’t think this one is possible from the length of time.
anyone know the number where Sw has to do something
I'll bet that there's no number at which SW "has to do something", but I also believe that the higher the vote count goes, and the more frequently bumps occur (to indicate this is not a deprecated technology), the more interest SW understands we have towards making this feature request come true.
Given Cisco's predominance in the router market, and that EIGRP is not longer Cisco-proprietary, one would think EIGRP support in NPM would be on some team's front burner.
ThwackCamp Bump!!
Also bump.
This request is rather vague (and old), so I'm not sure what it's looking to achieve. That could be why it hasn't garnered a qualified response.
To add 2-cents on version 12.2, it does appear NPM recognizes the node is participating in "Cisco EIGRP" and has neighbors (indicated by IP). However, it doesn't look like it's parsing/recognizing the EIGRP AS Number(s) of which the node is a member. I have a ticket open on the issue now, but it's unknown whether or not this is a part of the current feature set.
By contrast, a node participating in BGP does indicate the Autonomous System (AS) number. While I haven't checked all the routing protocols, it appears OSPF doesn't collect the AS number (or Area) either. Sounds like this may be a can of worms for SolarWinds to address, but competing products do this already (and have for years).
Routers report EIGRP neighbor changes to my NPM via syslog. They could also report via traps. And either could cause NPM to fire off an e-mail, send a text or a pager message, or even perform a script.
I wonder what specific functionality the original requestor familyofcrowes imagined?
Hello, community.
I just had a ticket for EIGRP closed under the guise of SolarWinds support considering my inquiry to be a "feature request." I couldn't believe what they said was not currently supported by the product. Get this: NPM can recognize that a node is participating and running an EIGRP routing process but, for whatever unfathomable reason, they do not record the Autonomous System (AS) ID of the EIGRP processes of which the node is a member. I mean, that just seems like the most basic information to collect in the process of determining whether or not the node is running EIGRP. Can this really be accurate?
The request in this current thread asks for EIGRP support. What could be more basic than this? This feature request is the #5 most requested for NPM, and it's been open since 2013. Surely, a "mature" product like this could not have overlooked that piece of the puzzle.
If anyone from SolarWinds is reading this, my ticket was called "EIGRP Processes and Autonomous System (AS) Memberhip" (Ticket ID 38726).
My guess is the only reason EIGRP wasn't added is that it's Cisco proprietary routing protocol but not sure why that should matter. OSPF etc. are open source protocol.
EIGRP was released as a standard to the general public in 2013 and is no longer Cisco proprietary. However, other router manufacturers seem to have set a standard of not adopting it. They still feel that Cisco's "Open EIGRP" standard tends to draw customers to Cisco routers.
I don't know which, if any, vendors besides Cisco sell or support EIGRP on their routers, and it's likely for that same reason.
I've talked with organizations that want to use EIGRP, but they fear it will impact their viability as targets for mergers or acquisitions by bigger companies that use OSPF or BGP instead of EIGRP. It's a funny worry to have.
I've been able to get what I need done with EIGRP. Wondering specifically what this post is asking for? I monitor my 'hubs' for when an EIGRP neighbor failed on them at remote sites. We use IWAN technologies so all our RBOs have redundant/multiple ISP connections with EIGRP neighbors. The branch doesn't have an outage and we have a ticket in our queue letting us know which site when down. The only thing I had to do custom was SQL to get the router that the EIGRP neighbor was down at. Here it is:
EIGRP neighbor ${N=SwisEntity;M=NeighborIP} (${N=SWQL;M=SELECT NIP.Node.Caption FROM Orion.NodeIPAddresses NIP WHERE (IPAddress = '${N=SwisEntity;M=NeighborIP}')}) gone down.
What's the trigger condition you utilize for this? Wondering if it would also work for other routing protocols ... specifically ISIS which is what we use (yea people actually do use it heh).
Opened up a ticket with SW to see if they could show me how to do this, but they weren't able to and said will need to be a feature request. Since ISIS is barely used I doubt that will ever get done so looking to do it myself.
Appreciate any additional information you could provide on this.
This is supported: https://support.solarwinds.com/SuccessCenter/s/article/How-to-create-alert-for-EIGRP-neighbor-status-change?language=en_US
Then why isn't the feature request closed?
@John.Summers @Walshy this has been implemented. Could you please check with the product managers and close this as implemented?
@ChrystalT can you please check with PM to mark as implemented?
