Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Migration from V7
romanwind
Hi all, I would migrate from Orion ver. 7.8.148 to Ver. 8. I'm dismissing old server and for this reason I'm installing on a new one. I have installed Solarwind software and I have created a copy of ver.7 sql server database. During installation phase I have an error during database check due to error columns and keys on database. Is there an utility to be used to migrate from ver.7 to ver. 8?
Thank you in advance.....
Find more posts tagged with
Accepted answers
All comments
Mithrilhall
Did you install v7 or v8 on the new server?
romanwind
Version 8
Mithrilhall
Did you attach the database to the SQL server before or after you installed v8?
romanwind
First time I started Orion after installation it ask me to create or use a database. During this phase I have selected a copy of v7 database. During check procedure I have some error due to impibbility of create or modify some keys and so on.
Mithrilhall
If the database was already attached to your SQL Server then installing v8 should have created the new rows...etc.
You could always uninstall v8 and install v7. Make sure it's working correctly. Once it is then uninstall v7 and install v8 and then run through the configuration wizard. When you get to the database part point it to the NetPerfMon database and it should do the rest for you (in theory).
romanwind
I'll try tomorrow morning (in Italy is midnight now), but I suppose I'll have the same issue. In fact the database was attached to a Solarwind ver7 and it was working fine. I will let you know. Thank you for your support
Network_Guru
It sounds like the new server does not have the required permissions to write to or modify the exiting SQL DB.
The normal way to migrate the DB to a new server is to backup the existing DB.
Then install SQL on you new server & do a restore of the backup.
Then install Orion & point it to this restored DB.
It must have the required permissions in the account used to access the DB to modify the DB.
Usually it requires DBA/SA rights to modify the DB.
-=Cheers=-
NG
~seek & ye shall find---> [url="
http://www4.solarwinds.net/SolarWindsForum/search.asp
<---no need to wait for answers~
romanwind
Ciao, I have same error. The error message is:
"The column ActionId in the table AlertActions does not have the Identity property enable."
I hava same error many times during wizard setup.
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
