The User Experience and NPM team is interested in learning about your Cisco ASAs. If you have a spare 5 minutes, please fill out this survey to receive 250 thwack points. Thank you!
Hi DanielleH,
I haven't received any points after completing this survey.
Nice survey concept though.
Is the survey close already?
Hi all - the survey is still open and points will be awarded once it has closed. Thank you for your participation!
For me it switches to Survey Gizmo but says we are not taking additional survey responses at this time.
Just received the Thwack community email now but "This survey is not accepting additional responses at this time. Thank You!"
- nice
Hello! You should have received your thwack points by now. Please feel free to PM me privately if that is not the case.
Hi everyone,
The survey is now closed. Thank you to everyone who responded!
Yea, I just noticed it in today's email also.
too bad it's already closed.
Hi ashley.orr DanielleH,
I have still not received points for completing this survey.
can you please check and let me know?
Regards,
Chinmay
No sign of points here?
It was on the previous weeks email, I just didn't notice it then.
Hello, my name is Radioteacher and I have a Cisco ASA problem. Truth be known, I have a great many ASA problems.
RT
Hello Radioteacher. How many days has it been since your last ASA problem?
Let's talk about it! I'll send you an email shortly.
I have not earned a 30 day chip in my 18 years here.
Looks like this thread should include #Coffee.
First 'coffee' tag! I'm honored to be a part of this.
Alright!
