Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
VB alert action
EuropAssistance
I have a wierd [at least I think so] problem.
I have an alert action set to fire a VB script to send an SMS message to support mobile phones. Everything works fine until I try and get Orion to pass an agument to the script, namely ${nodename}. Basically, nothing happens.
However, if I run the script from the command line and pass an argument, then all is OK, so I assume my fault lies within Orion.
Command I am running and the script follow. Does anyone have any suggestions?
Alert action: [cscript.exe selected]
s:\scripts\sms_node_down.vbs ${NodeName}
Script:
Dim ArgObj, node
Set ArgObj = wScript.Arguments
'First parameter
node = ArgObj(0)
' Variable declarations
Dim Engine
Dim Connection
Dim MobNum
Dim Message
' Create an instance of the Engine
Set Engine = CreateObject("SMSDo.Engine")
' Now the Engine has been created, open a connection - Parameters are Server, Username, Password
Set Connection = Engine.Connect("172.20.10.42", "rooster", "xxxxxx")
' Set the on call mobile number
MobNum = "+44xxxxxxxxxx"
' Set message to send
Message = "ALERT! "& node &" not responding."
' Send the message - Parameters are Number, Message, Reserved (always zero)
Call Connection.SendMessage(MobNum, Message, 0)
' Reset the objects to nothing to release allocated memory
set Engine = nothing
set Connection = nothing
set ArgObj = Nothing
Find more posts tagged with
Accepted answers
All comments
EuropAssistance
This was fixed by upgrading to version 7.1
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
