As we know about the clustering and we added the all cluster node one by one including the cluster name / Cluster resource into solarwinds for monitoring.
After some, if you are preparing a report about the cluster host and cluster name / Cluster resource, we can not identify which one node is part of cluster until you can not login in to server and check cluster / failover configuration.
Hence i would like to put this requirement as a feature request, So SolarWinds could auto populate the cluster node list and cluster name/ Cluster resource information in one view under node details page, if node is configured as a cluster.
thanks
