After upgrading to Orion 9.1, I get the following when trying to view the Syslog via the menu:
Orion Website Error
An error has occurred with the Orion website.
Additional Information
System.NullReferenceException: Object reference not set to an instance of an object.
at SolarWinds.NPM.Common.RegistrySettings.GetSetting(String appName, String section, String key, String defaultValue) in C:\Source\OrionNPM\DEV\Release\Orion\Core\9.1\Src\Lib\SolarWinds.NPM.Common\RegistrySettings.cs:line 75
at SysLogsReportControl.get_Columns()
at SysLogsReportControl.table_ItemDataBound(Object sender, RepeaterItemEventArgs e)
at System.Web.UI.WebControls.Repeater.OnItemDataBound(RepeaterItemEventArgs e)
at System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem)
at System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource)
at System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e)
at System.Web.UI.WebControls.Repeater.DataBind()
at SysLogsReportControl.GenerateReport(String netObjectID, String deviceType, String severityCode, String facilityCode, String messageType, String messagePattern, String period, Int32 maxRecords, Boolean showCleared)
at Orion_NetPerfMon_SysLog.PopulateChildControls()
at Orion_NetPerfMon_SysLog.OnLoadComplete(EventArgs e)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
Everything else seems to be ok. I also noticed that when trying to monitor an ESX server, the ESX Server view is not being used - and it is defaulting to the standard view. I did verify that for an ESX Server, it should display the ESX Server view.
Any ideas? Thanks!
- Mark
