Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
Monitoring Number of Connected Users on Cisco APs
aSquared
Hi there. Does anybody know if SWO is able to monitor the number of users connected per AP for the Cisco Aironet?
I am monitoring hundreds of APs in different buildings. At present, I am using MRTG to perform the above. I was thinking of doing away with MRTG since SWO is able to provide several statisitcs such as B/W utilization and Packet Losses.
Hope anyone can assist. Thanks
Find more posts tagged with
Accepted answers
All comments
Network_Guru
See this post in the EE forum:
www2.solarwinds.net/.../topic.asp
It was posted a while ago, & so far have not heard any more about this.....
-=Cheers=-
NG
Isaac
Hello,
No. Orion will not monitor the number of associated users on an AP at this time. You could either use the SW toolset to monitor this value or continue to use MRTG and hook the MRTG graphs to your device views in Orion. You could do a little custom HTML to imbed the MRTG graphs on the node page or create a link on the node page to the MRTG graphs.
Be fantastic.
Josh_Stephens
The SolarWinds Wireless Networks Management Pack for Orion is in beta now and will be releasing soon. You can monitor connected users, traffic, signal quality, and more depending upon which type of WAP you're using. If you're interested in using the beta, send an e-mail to Support@SolarWinds.Net attn: Wireless Networks Beta Program and we'll get it out to you.
Josh Stephens
SolarWinds.Net
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
