How to Stop the Use of Anonymizer Websites on Your Network
\m/
Very nice. Easy way to find out if users are using these anonymizer websites. Would the default list of sites get updated, and if so, how often?
Cool to watch. Glad there's an option for the web.
It's good that it's easy to add and remove these. The new SEM HTML5 interface to work with the rules is making it easier I think to edit your rules.
