cool
fist time I answer all correct woho!!!
My application ONLY will drive our decision to go to the Cloud. For now, we will remain on Private Clouds hosted by me! I have a wonderful design with a 3rd copy of my data that even I can't delete!
Might need to add an Air Gapped option to these sort of polls...
air gapped multi-network, multi-vendor solutions which do not integrate cohesively. I can neither confirm nor deny a government directed implementation.
Interesting to know
Air Gapped!
