Alright!
@JFollis - no problem, we'll make sure you get the points!
We just use the Orion Platform, but the Service Desk stuff sure looks sweet!I accidentally voted on this last Friday before I saw it was part of a mission, and thus didn't get points
I find that SolarWinds products are very proficient and productive .
I miss Dameware Remote Support from a previous job. It was so smooth to set up and pass credentials.
What, if any, of the listed SolarWinds products do you currently use?
I'm an Application Administrator so I live pretty much in Orion, SAM, and a tiny bit of NCM. Our technical services team does use the Dameware Mini Remote Control for remoting into machines for support issues - I'm not sure if that's part of Dameware Remote Support or if it's an older application?
I chose "I don't use any SolarWinds products" because there is no "None of the above" answer. I use SEM. It's a SolarWinds product, but it's not Orion, Service Desk, Web Help Desk, or either of the Dameware products.
"For the sick swag"?!?
Question, why are you a Thwack user, since this is SolarWinds?
"I don't use any SolarWinds products" ?
Missing the "None of the Above" option
