I need ability to set up at least few defaults for automatic ORION MAPS like IP Address, location or icon type for node. The best solution would be to replace automatically created map at Map tag with my own.
@JaroslawLadyga - Assuming you are needing a new UI/ Management screen to accomplish this correct? Or was there something else you had in mind?
@jblankjblank - Yes. I need something like a few options of UI/Management screen. It would be enough to add 2-3 settings in Web Console Settings (in PRODUCT SPECIFIC SETTINGS section) like for World Wide Map.
