IF YOU TAKE THIS POLL BEFORE FRIDAY OCTOBER 20TH OR FROM THE COMMAND CENTER VS. THE MISSION, YOU WILL NOT RECEIVE MISSION CREDIT
ZTA
+Other; There will also be benefits from educating the end users of the SolarWinds Platform via both support and training.
hard to say from an overall company perspective!
Building a new on-prem datacentre.
reduction in tech debt
hardware and compliance
They want me to create a NOC using Solarwinds. Can't wait. Just need Orion Maps in HCO.
Expanding connectivity to additional agencies and clouds.
Cost Savings
reduction of technical debt: virtualization, upgrades, patching, establishing a KB with SOPs, etc. (I am about 7 months into a new job)
next steps: DR improvements, automation (of deployments, patching and other maintenance tasks)
Cloud is costing way more than we thought it would!
Despite that all my stuff is on-prem.
automation
Hiring new staff to take on the complex environment roles necessary to comprehensively update and secure our systems.
dont pretend you arent just keeping the automation in your pocket so you can enjoy time away from the keyboard in your rv
Our priority for spending this year is to: not
Yep!
Update infrastructure and network security posture to increase our security standards and proactively lower risk to the network and enterprise assets.
Equipment refresh.
We are working on infrastructure refresh, security, and AI - we are using AI to quality assure the calls and to look out for the employee taking the calls. Very interesting concept and use of AI.
Nice
