Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Goal Oriented AI
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
upgrading to V7 on 2003
myexilus
Soon I will be installing the full Orion V7 on 2003 Server (SQL included. Do you have any suggestion on what files to backup on my actual V6 to preserve my database?
Your input is important.
I value your input.
Find more posts tagged with
Accepted answers
All comments
lutor
I've installed the version 7 on 2003. The website gives me ASP errors and the solarwinds support is still unable to solve it....
To migrate from the previous version you have to follow instructions contained in the admin guide.
Regards
lutor
Network_Guru
What is the ASP error message you are seeing and on what page does it appear.
I just upgraded to a newer, faster server and at the same time went from V7 to V7.0.5.
When I re-installed the telnet resource file in the "9-1-miscellaneous" I got an ASP error
message when viewing any node detail page.
Here is the 70-telnet.resource file that is caused the error:
"<!-- Title=Telnet -->
<!--#include Virtual=/NetPerfMon/scripts/NetPerfMon.asp -->
<!--#include Virtual=/NetPerfMon/scripts/Resource.asp -->
Title="Direct Access"
HelpPage="Node-Details"
DoResourceHeader
<% If Node Is Nothing Then %>
<span class="Text"><font color="red"><b>A Network Node was not selected</b></span>
<% Else %>
<table width="100%">
<tr>
<td colspan="4">
<table border="0" cellPadding="2" cellSpacing="0" width="100%">
<tr>
<td class="Property"><a target="_blank" href="telnet://<%=Node.GetProperty("IP_Address")%>">Telnet to <%=Node.GetProperty("IP_Address")%></a></td>
</tr>
<td class="Property"><a target="_blank" href="telnet://<%=Node.GetProperty("IP_Address")%>:25">Check SMTP <%=Node.GetProperty("IP_Address")%></a></td>
</tr>
<tr>
http://<%=Node.GetProperty("IP_Address")%>">Web
Interface <%=Node.GetProperty("IP_Address")%></a></td>
</tr>
<tr>
<tr>
</table>
</td>
</tr>
</table>
<% End If %>
<br>"
I just delete this file and everything works fine again.
Now I just have to figure out how to get the telnet resource back again....
For back-ups I just zipped up the following directories:
C:\Inetpub\SolarWinds
C:\Program Files\SolarWinds\Network Performance Monitor V7
C:\WINNT\Tasks
Copy the 3 zips to the new server, then you can restore any missing or required individual file at any time.
-=Cheers=-
NG
myexilus
Thanks folks,
I will migrate and let you know the results..
I value your input.
iunderwo
No need to include NetPerfMon.asp in your telnet resource. Everything you'll need is included in Resource.asp.
I ended up modifying mine so that it would only allow the telnet URL if the resource was SNMP pollable:
Title="System Access"
SubTitle="Managed Device Access"
NodeType=Node.GetProperty("ObjectSubType")
DoResourceHeader
<% Else %>
<tr>
<td colspan="4">
<tr>
<td class="Property" width="10"> </td>
<% If NodeType="SNMP" Then %>
<td class="Property"><a href="telnet://<%=Node.GetProperty("IP_Address")%>">
Telnet to <b><%=Node.GetProperty("DNS")%></b> (<%=Node.GetProperty("IP_Address")%>)</a></td>
<% Else %>
<td class="Property">No Access to Unmanaged Device</td>
<% End If %>
</tr>
</table>
</tr>
</table>
<% End If %>
// Ian Underwood - Service Management
// Level 3 Communications
Network_Guru
Thanks Ian,
I guess they changed the asp files between V7 & V7.0.5
It works fine now that I removed the NetPerfMon.asp line.
-=Cheers=-
NG
rix
I keep web access url right with the telnet, and use a custom property to handle any url definition, since they seem to be different for so many devices:
<!-- Title=Web Access -->
<!-- Level=7 -->
Title="Management"
DoResourceHeader
<% Else %>
<tr>
<td colspan="4">
<tr>
<td class="Property"><a target="_blank" href="<%=Node.GetProperty("webaccess")%>">Web Access</a></td>
</tr>
<tr>
<td class="Property"><a target="_blank" href="telnet://<%=Node.GetProperty("IP_Address")%>">Telnet Access</a></td>
</tr>
</tr>
</table>
</td>
</tr>
</table>
<% End If %>
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
