Not a fan of TheBeef but Eagle Eye was pretty incredible from a tech standpoint and still makes me think "who is watching" whenever I look at my phone.
On [mention:144f2fe4665a451dbccc5390df6ef96f:ca0e7c8086864d2fa5a863b9e212e922], we found 07. Eagle Eye (2008) to be silly but a lot of fun.
Went with A.I because the band Ministry was in the movie.
