Following: http://thwack.solarwinds.com/ideas/1364
We would like a SAM monitor to calculate the job weight to be used for historical trending. Thanks.
All SAM jobs are weighted equally. Can you provide details for the problem you're trying to solve?
Sorry. I should have clarified. We want the polling engine job weight.
Ultimately for us the important thing here would be having the ability to tell what percent capacity a polling engine is at with regard to SAM polling. My understanding is that the current Polling Rate capacity does not factor in SAM.
I don't think it is historical (I don't know where it is), but it is displayed in the web page, so there must be some math to create it... if SolarWinds just created a template and made it available to us... then it would be done.
The polling completion rate is not kept historically. We have found a way to keep that historically though, by just pulling it down with a SQL query in a SAM monitor.
