All of them, depending on the vendor solution.
right!
Wowza!
a, b, c and d
Roger that... more that one
No option to select multiple choice.
\m/
SQL, Azure SQL, Other SQL... SQL SQL SQL - whatever the App requires, the team wants, the devs want, whatever I am told to monitor...
Radio button so just picked the one that gives me the most trouble.
Tell you the truth, I have no idea...lol
lol yeah I have 4 of them at least... the first 4.
about to post the same thing!
No option to select multiple DB
its a radio button so we can only select one
