I'm not sure about what level I'm getting with my new HCO Advanced license that's coming. I did notice DPA 1 year license was included on the PO.
IF we ever had deployment services they would have expired long ago. Not sure the question has any relevance to customers whose systems were deployed some time ago.
No option for "none?"
Like 14 years ago.... I have mastered redeployment of my environment; I can do it start to finish (scratch install) in 17 hours; all the modules and all the data! Who needs deployment services!!! >??? Can I go help you!!!
and no option for "I literally provide an equivalent of these deployment services"
\m/
