Community
Command Central
MVP Program
Monthly Mission
Blogs
Groups
Events
Media Vault
SolarWinds Academy
Products
Observability
Application Management
IT Security
IT Service Management
System Management
Database Management
Goal Oriented AI
Content Exchange
SolarWinds Platform
Server & Application Monitor
Database Performance Analyzer
Server Configuration Monitor
Network Performance Monitor
Network Configuration Manager
SQL Sentry
Web Help Desk
Free Tools & Trials
Store
Home
Products
NetFlow Traffic Analyzer (NTA)
NetFlow Setup Problem
sk_5910
I'm pretty new to this & am trying out the NteFlow monitor in Orions (v8).
I have installed the NetFlow component to an existing Orion-v8 setup & the install process looked fine.
For some reason I am getting a yellow message in the NF Traffic Analyzer telling me:
NetFlow Receiver Service [NMA-ORION] is receiving a NetFlow data stream from an unmanaged interface on 172.16.0.226. The NetFlow data stream will be discarded. Please use the Orion System Manager to add Interface #11 in order to process this NetFlow data stream.
That IP address is a 2621 router that has all interfaces (S & FA) monitored in the NPM setup. NPM seems to work just fine looking at the data from the router. I am interested in the WAN data from the S0 interface, so I have setup the "ip route-cache flow" and "ip flow-export..." stuff for S0.
However, the message... & I don't know what it means by "Interface #11" anyway....
Can anyone help??
Simon
Find more posts tagged with
Accepted answers
All comments
pkeefer
I'm told they will be adding a feature to the upcoming release that will let you pick specifically which interfaces you want to accept data from on the netflow engine. Until then, I think the #11 refers to the IFindex value. You can pull this with an snmpwalker.
Paul
ceyko
You can also run the following and get the if index number...example below...
sumcompanyswitch#sho snmp mib ifmib ifindex
EOBC0/0: Ifindex = 124
GigabitEthernet1/1: Ifindex = 1
GigabitEthernet1/10: Ifindex = 10
GigabitEthernet1/11: Ifindex = 11
GigabitEthernet1/12: Ifindex = 12
GigabitEthernet1/13: Ifindex = 13
GigabitEthernet1/14: Ifindex = 14
GigabitEthernet1/15: Ifindex = 15
GigabitEthernet1/16: Ifindex = 16
GigabitEthernet1/17: Ifindex = 17
GigabitEthernet1/18: Ifindex = 18
GigabitEthernet1/19: Ifindex = 19
GigabitEthernet1/2: Ifindex = 2
GigabitEthernet1/20: Ifindex = 20
GigabitEthernet1/21: Ifindex = 21
FormerMember
You can also use the EE toolset "MIB Browser" to find the if index.
Use MIB "IF-MIB:ifXTABLE" (1.3.6.1.2.1.31.1.1) to view the info for your router/switch. It will give you the index correlation to the slot/port.
darryld
If you right click on an interface in the Orion System Manager and select Interface Details you will also be able to see the if index
FormerMember
This selection feature is available in NTA 2.0.
Denny LeCompte
Sr. Product Manager, Orion
SolarWinds
Quick Links
All Categories
Recent Posts
Activity
Unanswered
Groups
Help
Best Of
