Can someone help with the below alert?
What it should do is trigger the alert when the machine type is 'Windows', VolumeType is 'Fixed Disk', Volume Percent Used is greater or equal to 80% BUT if the NodeName contains VMW or SQL it should not trigger the alert.
The alert is triggering fine but it's like it is not reading the 'Ignore VMW & SQL' part as we receive alerts for servers containing these words, is this alert set out right?
Cheers,
